I have a very old AVO coil winder which I have fitted with a 24V DC motor. I need a variable speed and have achieved this with a Variac and 12V battery charger. This works OK but is bulky and I need my Variac for other duties. The motor takes 400mA unloaded at any speed. The current will be somewhat more when driving the winder and could be considerably more when winding thick wire.
What would be the best way of driving the motor?
1. Variable stabilised DC voltage. (LM2596)
2. PWM with no feedback. (555)
3. Linear voltage supply.
I have bought a buck convertor board based on a LM2596 (2Amp?) and will modify this to fit an external variable control.
I repaired a CB radio power supply modified for variable output but this has excess reservoir voltage and gets too hot even when the motor is unloaded.
On a separate topic, I need a couple of half nuts for the lead screws. Half inch diameter, 40tpi, buttress thread. Any idea of where to get these. I have a ordinary thread tap and will get a tame model engineer to make me two half nuts and see whether these will do.
