This weather station has a non rechargeable CR123 that goes flat about every 18 months. Now for a system that has a solar panel I find it unacceptable that every 18 months or so you either have to drop the mast to get to the station or grab a ladder and scale the mast (9m high in my case) For somebody in his sixties this is no joke and as I get older and more crotchety my language is not going to improve when I have to replace the battery.
Now how this thing works is the solar panel runs the station during the day whilst simultaneously charging a supercap that is meant to run the station during the night. Any shortfall by the cap is made up by the non rechargeable CR123.
For more info read here: https://www.manula.com/manuals/pws/davis-kb/1/en/topic/supercap-faults.
Let's just be clear, the station is operating as it should, I just feel Davis's design sucks.
As I see it options are:
1. double up on the supercap
2. increase the size of the solar panel. ( Davis do a bolt on solar panel but not for the Vue)
3. add in a charging circuit to facilitate the installation of a rechargeable battery
I will probably need to do all three.
I have considered feeding it mains power via a transformer but it means laying quite a long underground cable which also increases lightning risk getting back into the house.
I would appreciate some input here, am I going about it the wrong way?, are there any alternative solutions I haven't thought about, any bright ideas will be welcomed. I want to knock this problem on the head once and for all.
