davenn
Hi guys
OK here's something I cannot get my head around
This circuit is being discussed on another forum ( NOT MY THREAD) and the explanations to my questions about it
The guy is trying to figure out why its not working properly ( it drives a set of LED's via resistors( not shown above))
I commented, maybe unwisely....
which was responded with ...
I then responded ...
a response of ....
and ...
so please help me understand this current mirror thingy and how that lefthand transistor is operating in that configuration .... I just don't get it
thanks lots
Dave
there's another obvious fault in the circuit
the left hand transistor has it's base and collector legs shorted out
.... both legs going to the bottom of R12
That transistor is connected fine. It's a diode connected device set to control a current mirror.
how do you figure that ?
so the way its wired the transistor would ALWAYS be on in full saturation so what's the point of having it there ?
because the junction of R12, C6 is going directly to the other transistors
that transistor is being bypassed anyway
but because the transistor is fully on, the C6/R12 junction is effectively always grounded
just wanna know
a response of ....
R11 and R12 set the collector current of the first transistor, right at the defined edge of saturation.
The Vbe generated is then paralleled with all others so they have the same collector currents.
It is a ground referenced current mirror with multiple parallel output sinks.
and ...
The C6/R12 junction is not grounded at DC. It is ground from the point of view of noise which is what you want. It is just the input device of a simple current mirror.
thanks lots
Dave
