Current Measurement Rating
Hi, newbie here.
I have a multimeter (Sanwa CD771). It has max current measurement of 10A at 1000V. In my understanding, it means that i can measure up to 10000 watt. If thats true, does it mean that I can measure current higher than 10A at lower voltage? Lets say, 12v at 20A. Please enlight me masters :D. Thanks
1. Because the wire inside the meter will get too hot if more than 10 amps flows.
2. Because the program inside the meter may only be designed to read up to 10 amp.
But you can try 12 amps and see if the reading is 12
Harald Kapp
Plus there is probably a fuse that will blow at currents >10A.
The misunderstanding comes from a wrong interpretation of the meter's ratings. If can measure either up to 10A or up to 1000V. But not both simultaneously.
At 10A, there will be a very small voltage drop (a few hundred millivolt) to avoid overloading the meter and to minimize the influence of the meter's voltage drop on the circuit being measured.
At 1000V there will be a very small current (a few µA), again to avoid overloading the meter and to minimize the influence of the meter's current consumprion on the circuit being measured.
"The misunderstanding comes from a wrong interpretation of the meter's ratings. If can measure either up to 10A or up to 1000V. But not both simultaneously."
NO.
Basically the meter has insulated leads and you can measure either AC or DC up to 10 amp on a 1,000 volt line.
"At 1000V there will be a very small current (a few µA), "
At 1V there will also be a very small current (a few µA).
I personally wouldn't put that meter anywhere near 10A or 1000v.
the meter is cat111 600v. I would guess that's it's absolute maximum.
And only just got cat 111 by the skin of it's teeth.
youtube has many videos testing meters and Fluke tested 100's of Japanese meters. They all blew to pieces and caught fire.
If you want to play with high voltage and high amps, buy a dedicated tester.
And use your multimeter for home projects only.
Martin
You are combining two different specifications of the meter incorrectly. The 10 A rating is the maximum current the meter can sense without damage when acting as a current meter. The 1000V rating is the maximum voltage the meter can sense without damage when acting as a volt meter. The meter can be in one measurement mode or the other, never both at the same time; it cannot measure both things at once - that would be a power meter, a very different device.
ak
Current is what causes the fuse to blow, simply heat melts the fuse... for example to blow a 1amp fuse, you could use 1 aa battery and short it and blow it...
but you could equally use 1000v but only 1ma and while very deadly, that fuse should not blow...
amps x volts = watts
Total power is measured in watts
For my Fluke multi-meter I use the AC/DC Clamp on ammeter accessory, high range and no exposure to high voltage.
M.
