Does anyone have any good idea's to set a max current draw of around 83mA that is both cheap and small?
Problem is, when the circuit starts I get a spike that goes up to sometimes 200mA (12V) that lasts roughly 30ms. If I use a simple current limiting resistor the circuit does not boot up. I have tried using a large cap but it's too big, expensive and is not reliable (charged via 22R resistor). I have also tried using a LM317 in a current limiting circuit but this tends to cut the voltage to GND when the current is reached and stop the boot up.
So I'm looking for something simple that will very quickly reduce the voltage (not to GND) to boot up the circuit.
Any ideas
Any ideas
