Curious Connector - what is it?
Cursitor Doom
Hi all,
Can anyone tell me the name of this type of connector? It's the 5 pin
thin film thingy hanging off the bottom left of the chip which is itself
hanging off the bottom left of the device in the first photo on this page:
http://www.ebay.co.uk/itm/Black-LCD-Touch-Screen-Display-Digitizer-For-
Samsung-S8530-Wave-II-2-/390666094726?
pt=UK_Replacement_Parts_Tools&hash=item5af5838886
I have reason to believe it doesn't "plug into" anything as such, but
relies on pressure behind it to hold it against corresponding pins on the
pcb. On the reverse side of the chip there's a sticky pad which assists
in alignment, but without pressure against the connector itself, there
will be no connection as such if that makes any sense. Any ideas?
TIA.
cd.
Martin Riddle
Hi all,
TIA.
cd.
Maybe a common FFC/FPC flex cable connector.
<http://www.molex.com/molex/products/group?key=ffc_fpc_connectors&channel=products>
Cheers
Robert Baer
Hmm..i had initially tried that...worked this time.
PC boards that accept flex ribbon "cables" like that use a special
small connector that has a slide for locking the ribbon in place.
LCD displays, like those used in DMMs use a rubber-like "striped"
interface (alternate conductive black and insulating grey) to the PCB
traces, and mechanical pressure when mounted.
