Crystal Radio Tuning Capacitor
Dave.H
I'm planning to build a crystal radio similar to the one linked to at
the bottom of this post, but the specs call for a 30-160 pf tuning
capacitor, all I can find is a 60-160 pf cap. Will this still work?
Dave.H
Sorry forgot the linkhttp://scitoys.com/scitoys/scitoys/radio/ten_minute_radio.html
I have a variable capacitor in a junker 5 valve radio from the '60's.
This is marked 2 1215 What value would this be, how would I be able to
measure it, there's 4 terminals two have got green wires, one with
two, haven't followed them to see where they go, another terminal has
a ceramic cap to chassis ground, the other isn't used.
Mike
The 60-120pf will work. It will just tune a narrower range of frequencies.
Most of the old tuning caps were 2 section units. One used for the oscillator
and one for input tuning. The input tuning section was larger and should be in the
20-365pf range. I don't remember the typical values for the oscillator section,
but it was lower. Some had three sections and used 2 sections for input tuning.
The easiest way to measure it is to borrow a capacitance meter. Otherwise
a you'll need a calibrated signal generator (or generator and frequency counter)
and an oscilloscope to measure the tuning range, or maybe a grid dip meter.
If you can find an old transistor radio just take both the ferrite antenna and
cap from it and use them together. Don't expect too much from it and be sure you
have a good ground. Make sure the earphone is right type. A low impedance type
will not work well if at all.
Mike
When truth is absent politics will fill the gap.
Dave.H
Mike
I don't want it to tune a narrower range of frequencies, maybe I
should try the old capacitor I have
Phil Allison
"Dave.H"
** The AM band goes from 550 kHz to 1650 kHz = 3:1 range.
So, the RF tuning capacitor needs at least a 9:1 range - since frequency
is inversely proportional to the square root of the capacitance value.
Typical numbers are 15 to 200 pF for miniature types and 30 to 450 pF for
larger ones.
Coil design is important so there is not too much C included.
....... Phil
Dystopia
In practice I think you will find that only 198KHz, Radio 4 signal
will come through.
E
ehsjr
Yes, with a narrower tuning range. But you can add
switched fixed value capacitors to extend the range,
if you want. This is a kludgy arrangement, but will
get you the full tuning range:
S1 S2
--------+-----o o---+---o o---+
[C1] [C2] [C3]
Values:
C1 60-160 pf variable
C2 56 pf fixed
C3 30 pf fixed
Range(pf) S1 S2
29-41 Closed Open
36-68 Closed Closed
60-160 Open Open
The site you posted sells a variable cap for use in
their radios - that may be a better choice than
using the switch capacitor kludge.
Ed
Dave.H
S1 S2
[C1] [C2] [C3]
Values:
C2 56 pf fixed
C3 30 pf fixed
Range(pf) S1 S2
29-41 Closed Open
36-68 Closed Closed
60-160 Open Open
Ed
Thanks for all your help, I've found a better crystal radio diagram on
the internet, where I get to wind my own coil, something I wouldn't
mind trying, and I've found a source for the parts.
Dave.H
S1 S2
[C1] [C2] [C3]
Values:
C2 56 pf fixed
C3 30 pf fixed
Range(pf) S1 S2
29-41 Closed Open
36-68 Closed Closed
60-160 Open Open
How many turns of wire would I need to get a value of 230 mH using a a
carboard tube from a toilet or paper towel roll? The site I've linked
to in this message has some calculations, but I never was good at
maths.
http://my.integritynet.com.au/purdic/crystal_set.htm
Dave.H
S1 S2
[C1] [C2] [C3]
Values:
C2 56 pf fixed
C3 30 pf fixed
Range(pf) S1 S2
29-41 Closed Open
36-68 Closed Closed
60-160 Open Open
Ed
maths.
Sorry that should be 230 uH.
Mike
Somewhere around 100T of #24.
Try http://www.lalena.com/Audio/Calculator/Inductor/
or google for an inductor calculator if you don't like that one.
Your best bet would be to wind maybe 130T turns and addd taps
every 10T starting at about 70T, or unwind turns until you get
the right tuning range.
If you add more taps, who knows, you might pickup some shortwave
depending on antenna, ground, and receiving conditions in your area.
Mike
You might get some ideas from my simple coil winding Webpage. My coil
can use a fine tuner brass screw.
http://www.oldtemecula.com/theremin/ultimate2b/newcoil.htm
Also gutting a cheap $5 battery AM Radios found in discount stores
(BigLots)will give you a variable capacitor and ferrite rod coil.
Merry Christmas,
Christopher
Temecula CA.USA
Peter Bennett
S1 S2
[C1] [C2] [C3]
Values:
C2 56 pf fixed
C3 30 pf fixed
Range(pf) S1 S2
29-41 Closed Open
36-68 Closed Closed
60-160 Open Open
When I went to school, the values of capacitors in parallel added, so
the ranges would be (bottom up, on your table) 60 - 160pF, 116 -
216pF, and 146 - 246pF.
E
ehsjr
S1 S2
[C1] [C2] [C3]
Values:
C2 56 pf fixed
C3 30 pf fixed
Range(pf) S1 S2
29-41 Closed Open
36-68 Closed Closed
60-160 Open Open
Yup, me too. I drew it wrong. The intent was to have
the variable cap switched in series with the C2 & C3
combination, where C2 & C3 are switched in parallel.
Like this:
S1 S2
[C1] o [C2] [C3]
A-------+ +----+----------+----B
The effective capacitance is across A and B
The switches are shown in the open position.
Ed
Rich Grise
Try http://www.lalena.com/Audio/Calculator/Inductor/ or google for an
Your best bet would be to wind maybe 130T turns and addd taps every 10T
starting at about 70T, or unwind turns until you get the right tuning
range.
When I was a Boy Scout, we would make variable inductors. Take a TP roll,
and wind some manageable magnet wire around it, maybe #32-#36; close-
wound. Leave about 1/4"-1/2" of naked roll at the ends. Secure the
wire, do whatever you need to do to the leads, and fasten it down
to your board. I mean board, as in wood. Then, mount a post a few inches
away from it, that's as tall as the diameter of the coil. Get a strip
of tin, like from a coffee can lid or so, put a hole in one end, and
bend the other end into a "v" shape, lengthwise, as if it were a little
scoop. Make the 'v' long enough to accommodate the next step. With some
fine sandpaper, clean the enamel off the wire at the top of the coil.
Mount the tin strip with a screw through its hole into the top of the
post, and the 'v' on top of the coil, making contact.
Voila! Variable inductor!
If you've got the patience, you could make your own capacitor with
aluminum foil and Saran wrap. ;-)
Cheers!
Rich
