Hello, I'm trying to fix a Grundig CUC 2401 with picture brightness too high.
The problem seems to be in the brightness voltage supplied by pin 16 of TDA8442 that should be in the 1-3V range instead it is about 3.2V.
If I manually lower the brightness the voltage goes in the right range of about 2V and doesn't increase but I don't understand why at start up it is set wrong ?
I've already changed TDA8442, the video output IC TDA3505 and the microcontroller IC811 but it didn't fix.
The collector of RGB transistors on crt board are about 170V for red and blue but 150V for the green, shouldn't be all equal ?
Could someone please help me to troubleshoot it ?
Schematic: https://elektrotanya.com/grundig_cuc2401.pdf/download.html
The TDA8442 is at page 4
Many thanks!
Many thanks!
