CPU Fan Mod Help
Don B
I currently have an Athlon XP computer system. This system is great with
the exception of the CPU fan. There are two major problems with it, it is
very noisy and the "pitch" of the fan often changes, I suspect this is due
largely to slight voltage fluctuations.
The fan is rated at 12V, .16A and 1.92W Min voltage is 7V
What I'd like to do is drop the voltage a little, say to about 9.5-10v and
add a capacitor to the line to smooth out the voltage.
If I understand V=IR correctly, I need a 150 Ohms 1/2 W resistor to do the
voltage drop. Can someone confirm this?
What I do not know is how to select a capacitor to quite the line. I
suspect I need something pretty small, but again I have no idea how to
calculate the value.
Thanks for any input.
PS: I am aware to dropping the voltage on the CPU fan will reduce cooling
efficiency. I'm not really worried about it.
cpemma
with the exception of the CPU fan. There are two major problems with
it, it is very noisy and the "pitch" of the fan often changes, I
suspect this is due largely to slight voltage fluctuations.
10v and add a capacitor to the line to smooth out the voltage.
do the voltage drop. Can someone confirm this?
The fan impedance is 75R. So to reduce the voltage to 10v on a 12v supply,
resistor if Ohm ruled would be 15R, not 150.
However, most PC fans lose 300mV or so at the electronic commutation, and
many include a reverse-polarity protection diode, so of the 12v supply, the
motor winding may see only 11v, so there are other considerations to take
into consideration.
But at the end of the day, it's hardly likely that voltage fluctuations are
high enough to affect the fan noise but don't crash the computer - check the
fan mounting screws and/or bearing wear.
Brook Smith
From what you have said I am assuming your unit is using a 60mm fan. If you
are using a retail heatsink and fan, this is EXTREMELY illadvised. The
retail units are mearly adiquite as it is.
I to would suggest that you look into a new heatsink and fan combo.
The only reason I would see to do this is with higher RPM 80mm or larger
fans, and then as it is a CPU fan, a variable approach should be used to
ensure you get the results you want.
H
Harry Conover
ChadMan said:
Get yourself a quality fan/heatsink combo. What speed Athlon are you
running?
I have a Thermaltake XaserII case that has 5 fans + 1 CPU fan and 2 PS fans
that runs quieter than my 3 fan system at home. I recommend Thermaltake
cases
I had an Alpha cooler on the one at home and it was noisy. I changed fans
and
it runs a lot quieter now.
ChadMan
Exactly. I don'e see why someone is dorking around with a defective
fan, when fan/heatsink replacement are so inexpensively availalbe on
eBay and from other sources. I personally go through from 1 to 2 CPU
fans a year, and their replacement cost is typically $10 or less.
Harry C.
