I spent 6 years puttering and saving money, convinced I needed to go
offgrid, but once I had a price put together on an offgrid, up-to-code
(and wasn't that a delightful moving target) system that would do what I
needed, and the money to do so, connecting to the grid was cheaper, even
with copper going insane.
That kind of thing happens when there isn't a suitable off-grid
parcel. If you're willing to go alternative, then the best idea is to
find a parcel where the savings on the land is more than the cost of
the power setup. It doesn't work if the grid-connected land is say,
only $20k, because the off-grid alternative is unlikely to be
sufficiently cheaper to allow paying for a house-sized power setup.
But if you're comparing say, a $200k grid parcel to a $100k off-grid
parcel, then the potential is obvious. In my own case, our budget
could be stretched enough to fit the big picture of a large off-grid
parcel and everything required to make it work. The cost of the same
sized parcel near the grid would have been miles out of our league.
"Subsidy" here is a credit of approximately the power company's cost for
100 feet of crappy aluminum wire suitable for 100 amp overhead service.
Everything else is bought by customer. Heck, it costs $345 just to see
what it will cost.
The only time there should be *any* subsidy is if there's a tiny
number of line extensions compared to existing ratepayer base. Even
then, the purpose of the subsidy will tend to be more of a
rationalization than good policy. Power companies have enough
problems without being turned into de facto loan companies. The
relatively large subsidies that used to exist in our area were just
another factor in encouraging people to think in terms of someone else
saving them from their failure to think ahead. A typical example - I
was talking to someone who'd purchased truly crummy property on a
flood plain miles (and decades) from the grid. He wanted to know if
the nearby wash ever flooded, and when the power lines were coming.
So, just remember to report your total input costs divided by the number
of KWH you use. If your $6000 system has produced 600 KWH, you're at
$10/kwh...
No, that's narrow thinking that should be discouraged. Every off-grid
parcel costs *something* less than a comparable off-grid alternative.
So that needs to be figured in, as well as the costs of living
off-grid, which generally means rural. For example, the off-grid guy
might need his own snow plow, and grid guy will probably pay higher
taxes. Always think big-picture.
Wayne
