John Doe
Does this sound right?
drill battery and controller
no-load
driving the drill motor
lowest-speed
1 amp
full throttle
2.8 amps
driving the scooter motor
lowest-speed
1.5 amp
full throttle
10 amps
What concern is there about the cordless drill speed controller
(trigger stuff, PWM, whatever) overheating? I suppose a temperature
monitor could be used, if necessary. I could lose the cordless drill
controller without crying about it. Also, I am dealing with lithium-
ion batteries, so would not want the controller failure to make the
batteries somehow catch fire or explode?
Thanks.
The cordless drill is a Bosch 36V lithium-ion hammer drill.
The scooter motor is something like this.
Brush DC Motor XYD-13
Specification
1.Voltage:24-48VDC
2.Rotation:CCW
3.No load: No=2600rpm±10% Io=2.5 A REF
4.Load:T=2.2N.m Nn=2600rpm±10% In=34.0 A REF
5.Lead wire:10AWG Black- Red+ 350±30mm Long
6.With pitch to 6.35mm, roller diameter of 3.3mm,
11 teeth sprocket. Motor diameter of 101mm,
a length of 95mm.
no-load
lowest-speed
1 amp
full throttle
2.8 amps
lowest-speed
1.5 amp
full throttle
10 amps
Thanks.
Specification
1.Voltage:24-48VDC
2.Rotation:CCW
a length of 95mm.
