Someone gifted me an LED Work Light. Specifically a Utilitech Pro 12W # MPL1022-LED12K8040
https://www.lowes.com/pd/Utilitech-Pro-1000-Lumen-LED-Portable-Work-Light/1000260469
The casing is entirely plastic (+ glass front), no vent area and double insulated with only AC 110V live/neutral power cord.
It runs hot and other owners report short lifespan. I'd like to fix that.
Inside the mains 110VAC power cord is soldered directly to a thin (1mm?) mPCB that both the driver circuit and LEDs (15 in series) are mounted on. This mPCB sits on a heatspreader sheet of aluminum barely thicker than tin foil, held together by metal screws. I have some much thicker sheet aluminum that I could swap in and would be entirely encased in the plastic case, -OR- I could go with an aluminum heatsink sticking out the back of the plastic casing after a hole is cut for it.
The concern is with that line voltage present at the mPCB, if that mPCB were coupled to an aluminum heatsink exposed in the rear, it seems like it would be unsafe. I could add a huge silpad (but I don't have any and ordering that could cost as much as the light did) and still there's the metal screws connecting them.
Would you consider it safe enough to replace the original power cord with a grounded cord and earth ground an added, rear exposed aluminum heatsink, plus put a fuse on the live mains input? -OR- would you just replace the approx 0.35mm thick original heatspreader pictured with one 2mm thick? -OR- would you just use it till it failed then throw it away?
I'd like to not drill vent holes in the case, but could seal around a heatsink and keep it [poorly] water resistant. There is no gasket or conformal coating from the factory, it was never waterproof.
I suppose pics are worth a thousand words.
https://imgur.com/sXdq5Hq
https://imgur.com/a/i1LQY
