I picked up this exercise bike, an Exterra UB1.7 model and it appears to have a fault in the magnetized resistance/effort circuitry. On these bikes there are typically and Up/Down arrow to increase/descrease the apparent load/effort on the pedals (aka "Resistance" in the mechanical sense).
From the console readings, everything on this bike appears to operate fine except resistance. As soon as one attempts to increase or decrease resistance on the panel, the unit flashes "E1" on the console. From the owners manual (see pic below), this is indicative of one of several issues:
For the E1 troubleshooting issues, I've eliminated issues 2 and 4 and I'm now focused on 1 and 3 (Console or gear motor circuit). Replacing the gear motor with a known good motor has no effect so I moved on to the console and opened it up.
After opening the console I found obvious signs of damage. Even still, perhaps amazingly, I find that the entire functionality of the bike, and the panel readings appear to be fully functional but for the resistance control. Even with the capacitor fully removed, the same functionality is present.
The bottom left corner of the console board appears to have some rust and corrosion on several screws and the 16v 1000mu capacitor had one leg completely out of the socket on the board. I removed the capacitor and did a quick test on it and it appears OK. There is some significant corrosion on the board at this capacitor so I attempted to desolder the plugged holes where this capacitor was and try my best attempt to replace this capacitor in circuit (my solder work there sucks), but I'm still getting the E1 error.
Pics attached if you guys have any ideas for next steps.
The circuit board. The loose capacitor is the top board bottom left:
Rust on the screw holding the voltage regulator just above the 16v 1000mu capacitor:
Reverse shot of the top board. Area of interest is now bottom right over flipped over board:
The "resoldered" pins of the capacitor. To the right of the pins solder is spot where a rusted screw head meets the board when its turned over and secured in its normal position. The board is flipped over here for this picture:
![61534301_2354155794647265_7284736310403661824_n.jpg](/forums/proxy.php?image=https%3A%2F%2Fscontent-atl3-1.xx.fbcdn.net%2Fv%2Ft1.0-9%2F61534301_2354155794647265_7284736310403661824_n.jpg%3F_nc_cat%3D103%26_nc_oc%3DAQms0FPJoGwm2jJ3l64xhUP_gpUvOeLpYoG0-evR_LJ-E9FfSSy4fqJbuc3E2ccoK84%26_nc_ht%3Dscontent-atl3-1.xx%26oh%3Df3e882a63ddf10749d0f7519695b5d59%26oe%3D5D56EF16&hash=d3d6257907f4c9d10eb7b5197cdac5d3)
![61748917_2354155784647266_2138907891095044096_n.jpg](/forums/proxy.php?image=https%3A%2F%2Fscontent-atl3-1.xx.fbcdn.net%2Fv%2Ft1.0-9%2F61748917_2354155784647266_2138907891095044096_n.jpg%3F_nc_cat%3D104%26_nc_oc%3DAQn8mocIu2WxF33pm6EXCOEjuGMiACYLH9Iq5_iTnginsELCXR-vz8vFxlqNnb0BP1g%26_nc_ht%3Dscontent-atl3-1.xx%26oh%3D25687d2e8476cad870c0da49b3b5efb4%26oe%3D5D9CC5AA&hash=e9e7e34347ebbb9f3ef1f7c5ee01399f)
![61495329_2354126674650177_4651804096758546432_n.jpg](/forums/proxy.php?image=https%3A%2F%2Fscontent-atl3-1.xx.fbcdn.net%2Fv%2Ft1.0-9%2F61495329_2354126674650177_4651804096758546432_n.jpg%3F_nc_cat%3D104%26_nc_oc%3DAQmJSrQqqcxbzifrKqbCbtE8jUCU4PSDnZzUAhl5sM-wTRtDcIELSNSCXj7fFsdO2TA%26_nc_ht%3Dscontent-atl3-1.xx%26oh%3Dcac8d18e0ddba963d395279346036895%26oe%3D5D5F0AA8&hash=8dc4a3ba1d1ab029ef954dfad607c5a0)
![61566584_2354126684650176_5688772930461237248_n.jpg](/forums/proxy.php?image=https%3A%2F%2Fscontent-atl3-1.xx.fbcdn.net%2Fv%2Ft1.0-9%2F61566584_2354126684650176_5688772930461237248_n.jpg%3F_nc_cat%3D103%26_nc_oc%3DAQkVBoOxZiOm2QGirWDWQuPDMTI2FxyCHD782EIa4QLNRpDCeDxo3hyZKpUkph4cVx4%26_nc_ht%3Dscontent-atl3-1.xx%26oh%3D6ac1dff232b6cd190b85fc1cfd1bf310%26oe%3D5D98D289&hash=9e78d77634f13dc611bde1c533a4c6fb)
![61884732_2354126677983510_4110949422202880_n.jpg](/forums/proxy.php?image=https%3A%2F%2Fscontent-atl3-1.xx.fbcdn.net%2Fv%2Ft1.0-9%2F61884732_2354126677983510_4110949422202880_n.jpg%3F_nc_cat%3D110%26_nc_oc%3DAQlga7U3SPhc1SY0Q-cDH6eFafsJ3xLvfdgwuS9fzF8IEou_X63dBgKMPNXvK71XDKQ%26_nc_ht%3Dscontent-atl3-1.xx%26oh%3Da6985c729e9c5638d9d304738ebef232%26oe%3D5D9F1EED&hash=240e7372af6b281ab3c57dcc3711e5f9)
![61602374_2354126547983523_7268798339603234816_n.jpg](/forums/proxy.php?image=https%3A%2F%2Fscontent-atl3-1.xx.fbcdn.net%2Fv%2Ft1.0-9%2F61602374_2354126547983523_7268798339603234816_n.jpg%3F_nc_cat%3D107%26_nc_oc%3DAQl5_0OcY4bYMA32iDJ_UFWKKqQyA_k-TmhFXKaR-bLTGFssnZetUdLhlfjH0iC4Kzg%26_nc_ht%3Dscontent-atl3-1.xx%26oh%3D911b9401d5db0fe59ed3db2dc22ffb0b%26oe%3D5D5F4F83&hash=a1f23c7d42704df4e5732e91e650c16e)
![61582812_2354126691316842_4819850606384513024_n.jpg](/forums/proxy.php?image=https%3A%2F%2Fscontent-atl3-1.xx.fbcdn.net%2Fv%2Ft1.0-9%2F61582812_2354126691316842_4819850606384513024_n.jpg%3F_nc_cat%3D104%26_nc_oc%3DAQmWzxIPHw8PXrOx5KoYwPKhWeIs7980IzFURuVD8mJ8vXcuLVyEaF5-BGfm15bKdsc%26_nc_ht%3Dscontent-atl3-1.xx%26oh%3D6568eb10a0fe2d887410dedecca648f6%26oe%3D5D89BA4E&hash=4595f316981f0b62e53e25c441400baa)
