G
gore
Does the NEC say that you can only connect one set of wires per device in a
box? The reason I ask is because I was working with an electrician and he
had me pigtail every connection where we fed multiple outlets with one feed.
Here's what I don't understand about that. If I am running a feed to a
pigtail which is made using either wire nuts, or those push in three hole
connectors, how is that a more "failsafe" connection than using the screws
on the sides (top and bottom) of the outlet? I have seen times where a
wirenut has fallen off of a connection (I assume from vibrations caused from
walking or jumping around) and the push in connectors, although very quick
to use, seem to work similar to the push in feature in the back of outlets
which I was told from a teacher never to use because they only make contact
with a small area of the conductor and that isn't as solid of a connection.
Would someone clarify this for for me? I wired my house using the top and
bottom of the outlet and just pigtailing the ground, but now I am thinking I
might have to go through and add pigtails to the hot and neutral too.
