I'm trying to sort out the installation of 2 4-wire smoke detectors to
my Ademco Vista 15P panel. According to the instructions, I need to
connect power in a way that will allow the smokes to be reset. It
looks like the panel has a "trigger" point, where if I connect the +
power and program the trigger correctly, it will power down/up to
reset. Other than that, if I connect the power to auxillary power, the
smoke will not reset, which I'm assuming may contribute to possible
false alarms. Another alternative is to install a separate relay to
reset, but I don't really want to do that.
Am I on the right track with this? Is there a better alternative?
Does the "trigger" option work well?
Thanks, in advance, for your help!
Rob Houston
Rob Houston
