I've heard from way back that connecting batteries in parallel is a bad idea.
I've heard a couple reasons. One is that it can be hard to make sure the
batteries are loaded equally. Another reason I heard is more complex. It
says that parallel connection should be done only on a per-cell basis, and
that a series/parallel combination would thus have parallel connections at
every cell ... and therefore multi-cell batteries are bad in this regard
while single cell (2V) "batteries" are the way to go.
Some googling revealed a few web pages that seem to not have much reference
to any parallel connection issues, aside from making sure the batteries are
the same size/capacity.
I would think that self-charging (a stronger battery charging a weaker one
connected in parallel) would not be much of an issue for a batteries that
are intended to keep a float charge, anyway (lead-acid is all that I am
considering here). If any battery has a problem where it can't take a
charge and could be a hazard if charged, then it seems one would have a
bigger issue by that alone than anything related to wiring them in parallel.
Maybe there are issues when the _number_ of paralleled batteries is high?
Series connection would _seem_ to be more of a problem, but clearly isn't a
show stopper at common voltage levels (12 to 48). What I refer to when I say
this is the risk that a single weak cell in the series woould be effectively
"reverse charged" by the "brute force" of the high voltage series circuit
forcing the current in the reverse direction than a charging current. On the
face of it, this risk seems like one that, if it could happen, would happen
on even a small a voltage as 6 volts (3 cell). But maybe for lead-acid the
risk is merely depleting the bad cell to zero and destroying it and nothing
more?
What risks ... to the batteries themselves ... exists in a very high number
of cells in series wired for very high voltages (120 to 600 volts for example)?
I remember running across, a few years ago, a very large DC to AC inverter
that was designed to run from a 576 volt battery configuration (which would
be closer to 600 volts). So it might seem that such setups are possible.
That wouldn't necessarily say there are no risks, as such a setup would be
an industrial one that could be well supervised for the issues that could
happen. But I would like to know what potential issues to watch for in a
home setup that could be wired to as much as 48 volts.
Would particular sub-technologies of lead-acid batteries matter in this regard
(aside from making sure all are the same type)?
Who here thinks connecting batteries (one cell or multi-cell) in parallel is
bad ... and why (if you don't know why, I'll assume it's myth).
Is there any advantage to using a big single cell (other than it's really big
current capacity, which itself may eliminate the need to even have anything
wired in parallel)? Example: Surrette 2KS33PS
more?
