I tell lies! I just litterally swapped the positive and negative around from the signal generator to the amp and it worked hooray!!! Thank you so much my very first Amplifier
progress
Good to hear!
Do you have a capacitor between the signal generator and the transistor of the amplifier?
Oh no I've burnt so many things out experimenting. Tell me this can my 30 vault bench machine kill me?
Yes and No...
Not normally directly, but indirectly yes.
Your body and skin has electrical properties just like any component you put on the board. Human skin varies in resistance but when wet or damaged the resistance drops quite a bit! The resistance of your body and the voltage it is exposed to directly relate to how much current is going to pass through your body. This is the dangerous part. Current is what can cause your heart to stop pumping.
Take a read at this wikipedia article as you continue to read, or after you have finished reading this post.
https://en.wikipedia.org/wiki/Electric_shock#Body_resistance
5% of the human population has a resistance from hand-to-hand of 1,750Ω @ 25V. This would allow 14mA to travel through the body. According to the graph on the same article, this could cause muscle contractions in the body. This would not be pleasant. If your hands happen to be wet or sweaty, that resistance will go down, and according to the same graph, allowing 30mA from hand-to-hand will present a chance of fibrillation which may lead to death if not immediately or very quickly attended to.
So... your 30V power supply, when cranked up to it's maximum voltage has a chance of causing bodily harm. The chance is very low, and relies on being applied to wet or broken skin, but the chance is there. The information I provided from the article is based on hand-to-hand contact which will travel across your chest. Please note! The heart can be kicked out of it's natural rhythm by *much* less current if directly applied. Additionally, the closer the wires are together on your body, the lower the resistance will be! It's possible to cause burn marks or damage to the body with your power supply if you put the the positive and negative leads close enough to each other on your body.
If someone told you to touch both ends of a pair of jumper cables to your body, I'm sure you wouldn't do it. Your power supply will provide almost 3 times the voltage of a car battery. Treat it with respect.
Now, I don't mean to be a fear monger. I'm telling you what is 'possible', but the probability of you hurting yourself with is is pretty low unless you are incredibly unlucky, and ignorant of safety precautions. I quoted worst case values.
It's *always* good practice to work on your circuit with power turned off when possible. If you are working on a live circuit, avoid touching any conductors with your live skin. Try even harder to avoid touching two conductors at a time, and try your hardest to never touch a conductor with each hand.
Use your best judgement when dealing with electronics and you'll be fine. Keep your eyes out for capacitors, because they are *very* high energy storage tanks that can unload in a fraction of a second... Make note of the voltage they are rated for. I bring these up because cameras often operate on between 1.5V to 6V, but often contain over 300V inside! Just because a circuit uses a low voltage for a source, does not mean it's voltages inside are also low.
*Now that I've said all that... if your power supply is set to a lower voltage many of these concerns would be addressed right then and there... additionally, if the power supply has a 'current set' feature, you could limit the current output as well which would help. I would not let my son touch 30V, but I would certainly let him play with 12V and below. If he was safe about it, I'd let him work on higher.
Of course, if you have any specific questions. Please don't hesitate to let us know.
Many of us have had our fair share with electricity and have most likely touched mains voltage or higher.
It's not pleasant... but electricity will flow from point A to point B. The golden rule is to *never* place your heart between those points.
Many others can add to this as well.
