Phat Bytestard
Hi, i'm designing an inverter, and i'm having problems connecting the
pcb tracks to the output cables, the current is 40 A. I have thought to
solder the cable to the track but i think this solution is a little
shoddy work, so some suggestions to make this?, thanks in advance.
You can place traces (big and wide @ 4 Oz copper) on both sides of a
two side PCB, and then place an area (tab shaped at edge of board)that
has six or eight huge through hole vias in it. with a notch about 5 or
6 mm in for the wire sheath to fill, the strands get split up and fill
the eight vias evenly. Place two non plated holes around the notched
area so that a tie wrap can hold the large wire sheath tight A set of
four non plated holes would allow TWO tie wraps, but the notch would
have to be 15 mm or such other appropriate depth. The multiple vias
split up the current rushes and dissipate any heat better than mere
traces do as well. The dual trace allows for some current sharing,
and is not typical for this industry. Single sided is cheap for power
supply industry. 2 sided is Cadillac.
There are also edge mountable solder cups that would allow you to
attach one (I still recommend the vias for heat distribution if
needed) and then place the cable end in the solder cup, and one solder
joint later, you are in business.
For 40 Amps on the input side, I would not recommend a single sided
PCB solution.
