Ross Herbert ha escrito:
What do you know about me? maybe i'm not going to make the inverter and
is only a prototipe design, or maybe i'm in a team, and my design part
is only make the pcb,and the hard electronic part is done by another
people, or maybe another person give me all the design except the pcb i
have to make the pcb, or maybe..., and if you are so smart that you can
tell the people what they can do and what they can't do, why don't you
answer the question?, if you haven't got any useful to say betther not
say anything,
Perhaps my sarcasm was a bit over the top...
You did say "I'm designing an inverter..." so it is logical to assume
that you meant what you said. If you were only responsible for the PCB
design then you would first need to have the schematic and component
makeup fairly well established and that can't be done in isolation
from those responsible for this part of the project.
The problem you have asked about is something which power designers
have had for 60 years since PCB's started to appear and there are
numerous examples of how the problem has been overcome, particularly
in heavy duty bench power supplies, battery chargers, UPS etc., So, if
you had taken the time to look at some of these examples the answer
would have started to become clear.
In the 1960's there weren't forums like newsgroups where lazy people
could just ask and hope to get all the answers on a plate without
doing any research themselves. They had to go out and look at what was
available and even design new and novel solutions if nothing was there
already. It all took time and considerable effort. Nobody minds
helping others to solve a problem where it is evident that they have
at least done some research. However, I have noticed that a number of
queries such as yours emanate from people who have obviously not done
one jot of investigation or research. I don't think those people
really deserve to be simply handed the benefit of hard work done by
others, just because they know the knowledge is out there. Do some
research, look at examples of other equipment, and study connector
catalogues first, like we had to do. If that doesn't produce the
desired result, then you can ask - but when you ask you should explain
how hard you have tried already so we get the right impression.
