F
FunkyPunk FieldEffectTrollsistor
A part is also a sealed assembly!
No shit, dumbfuck.
Ifsaid 'sealed assenbly' get BAKED in an oven, there will be NO water in
it, and if said assembly is subsequently sealed further, there is going
to be a greater NO water content level in it, THEREFORE, if an entire
assembly get baked, as is the STANDARD procedure for assemblies prior to
sealing operations, then there will be NO water INSIDE the seal.
AFTER the sealing operation, there will be no water getting in as well.
Where your brain went askew is unknown.
So if a small sealed assembly can't
keep the water out, a big one can't either.
If only we could have kept your mother from getting any water, we would
then not have to listen to your utter stupidity.
Ofcourse you can use
better materials which slow down the ingress of moisture but
eventually you'll have moisture inside.
You're an idiot. There are coated assemblies out there in the harshest
of environs that have lasted for decades.
That should be a hint for you, and your blatant Obama styled lies.
