This is absolutely my first try in designing a concept circuit. While I'm certain there are so many other ways to do this, I decided to stick with the easiest components to find --- the 555 timer.
In theory, this block Diagram Should first send multiple On/Off Pulses to Load 1, and then turn on Load 2 after a determined delay in the R-C circuit
The idea is to time the pulses in Load 1 so that it turns on and off only for a given time - then after Load 1 is done, Load 2 would turn on - and Stay on until the Bistable circuit is reset - turning off everything. Of course making sure that time set for load 1 is not greater than the time the RC Circuit would turn on.
So... would the above block diagram function the way I anticipated it?
