we had this old computer lying around that we don't use anymore and I needed a Lab bench power supply. i find the output voltages appealing as it matches the common voltages you can get - like from batteries.. so i thought of converting one.
After following some instructables, i got the ATX supply to work, and using a small voltmeter, i got the output voltages, +3.3, +5.4, and +12 volts, I didn't need the negative voltages (who does?...) those positive outputs seems ok - no visible issues... The "dummy load" is on the +5V rail as it has the most current: 20A
Now.. i didn't exactly like the idea of having one terminal for every output voltage, so i came up with the idea of using an SPTT switch(not sure about that name) on the schematic below:
(the switch can toggle around the three voltages)
So, after adding this switch, everything seems stable. I can toggle between 5V and 3V - totally ok, but when i try move up to the 12V something funky happens. The supply stays on while on 12V, but when i move down to the lower voltages, the whole ATX supply suddenly turns off - nothing blew up(whew!, just turned off by itself). So i can move on the 3V and 5V ok, and even move up to 12V, but when i move down from 12V to the lower voltages, thats when the supply suddenly turns off...
my guess is that, the ground recognizes the difference of the voltages it receives and turns off if there's a huge spike....
could this be correct?...
