Hi everybody,
I have a 1mH, 10A common mode choke. Can I use this as an inductor with
the same specs?
If yes, how? Like (a) connecting one winding and leaving the other open
or (b) paralleling both.
Sorry, no. A common mode choke is wound such that the load
current (the one rated at 10 amperes) trough one coil
magnetizes the core in one direction, while that same load
current, returning back out the other winding, magnetizes
the core in the other direction. So the fields of these two
currents cancel, preventing the core from saturating, and
producing very little inductance.
The device shows 1 mH only for current that goes through one
or both windings in the same direction, so that the fields
do not cancel. In line filter applications (where these
devices are usually used) this common mode (same direction
in both sides)current is very much smaller than the load
current (that goes in one winding and out the other).
For instance, the common mode current may be a result of
voltage that is in common on both line wires, like signals
picked up from local AM stations by the line wiring acting
as an antenna, or generated by diode switching or switching
regulator operation on the load side.
The core of a common mode inductor is generally a solid,
high permeability ferrite (with no air gap) to maximize the
winding coupling and inductance, since the common mode
signals are generally very much smaller than the load
current. They are really a form of transformer with two
equal windings.
Normal mode inductors (two lead devices) generally are made
with distributed gap powdered iron material that takes a lot
more turns to produce the same inductance, but are
saturation resistant, because of the nonmagnetic gaps in the
flux path that store energy when a magnetic field is forced
through them.
