USB-B jack with common mode choke?
Joerg
Gents,
Does anyone remember a manufacturer that makes through-hole USB-B jacks
with common mode chokes in there? Preferably with a metal flap that can
also be grounded against a front panel.
Came upon a situation where they didn't place CM chokes on the board,
trying to see if it can be remedied sans relayout.
O
Oppie
Joerg said:
Gents,
I had just been using a ferrite bead and passing the USB D- and D+ lines
both through it.
Joerg
both through it.
Looks very tight in our case but that's an idea. Maybe we can find a
really flat bead.
Robert Lacoste
Joerg said:
Gents,
Hi Joerg,
You can also use the same solution that the trick used in plenty of, well,
east-designed products : ship it with a USB cable with a built-in ferrite
bead on the device side. That way the "product" is the cable+device kit, and
your EMC certification will pass without problem. Of course your customer
may have issue if he use another USB cable, but that's no longer your
problem ;+)
Friendly yours,
Robert Lacoste
www.alciom;com
Joerg
Robert said:
Hi Joerg,
problem ;+)
A big ferrite over the whole cable isn't helping, just a tiny ferrite
over only D+ and D- (together, or course) is what helps. Haven't found
any cable that has those. If anyone knows a source I am all ears.
