rich
Hello all,
I need to to drive a 300mA resistive load with an variable voltage
of 0-30V. Right now I have a NPN transistor in the common collector
configuration.
The collector is tied to the supply voltage which can be 10-30V. The
base is driven from 0V up to the supply voltage.
This works just fine up to a supply voltage of about 20V. I can vary
the base voltage from zero to that and get a nice output without too
much heat.
Above this however I get way to much heat, even at small loads.
The transistor is in a sot-223 package with a pcb copper pour area as
a heatsink.
What is a better way to construct a voltage follower that will
dissipate less heat? Perhaps switching to a p-channel mosfet?
Rich
configuration.
much heat.
a heatsink.
Rich
