From post #14:So please clarify how it gets changed depending on gain?? Is there any equation??
Ic = Ib * hfe (3 * 100 = 300mA)
Ie = Ib + Ic (300 + 3 = 303mA)
ak
So if beta = 300, thrice the current will exist (Emitter current), but how?
I only knew few equations that's why I went through all this steps to connect beta and Ie. but from your reply "You'r lost at sea" I guess I'm wrong.
One more Is there any current flowing through collector ( current taken from supply connected to Collector??
Or is it only flowing through base - emitter circuit?
May I point to the fact, that Vbe does not "drift" with rising temperatures? Instead, it is the collector current Ic that increases with the temperature - and we have to reduce Vbe externally by app. 2mV/K to bring Ic back to its former value.
So - where is the advantage to view the transistor as a current amplifier?
Remember: The tempco is -2mV/K for Ic=constant.
beta=300 is 300 times, not 3 times.So if beta = 300, thrice the current will exist (emitter current), but how?
I have never used the transconductance model in a formula in hundreds of designs.
But you can use the transconductance formula if you choose with an ideal voltage source.
