I know, I'll be hard to teach idiots like me but I still have few more doubts. And hope you have patients for that.
This what I understood so far,
When a base voltage is applied base current flows and this is multiplied by transistor gain to produce a higher current, this current causes a higher voltage across load. Since base voltage is constant, this cannot happen.
So emitter current and voltage increases till voltage across load is it's less that 0.6V that of base voltage.
In other words increased collector current will increase emitter voltage , SInce Vb is constant increase in Ve reduce the Vbe, this causes Ic to reduce.
When a voltage (5V) applied to base, base current flows(say 3mA, and it's amplified by transistor to a higher value depending upon it's gain(say 100)
So Ie = 300;
You supply a voltage of 5 V to the base resistor, not a current.
What I meant is if Ib = 3ma, where does the remaining current comes from, Is it from supply connected to Collector?
(But i could 't find an equation connecting base current, emitter current and gain hfe.
Is it like this, Ic/Ib =hfe,
So, Ic = Ib * hfe (3 * 100 = 300mA) ------> increased collector current.
Ie = Ib + Ic (300 + 3 = 303mA) -----------------> Emitter current increases as a result)
Is that how I get high current through load from a low base current?
. This higher current will cause a high voltage across load(current high, resistance constant)
If load has a reistance of 40 ohm, then voltage across load is
Vload = 50 * 0.3 = 15V (should I use 300 ma and 303 ma, even though it won't make much difference?)
But this cannot happen since Vbe = 5V ,( By KVL 5V = 0.6 + Ve ========> Vbe = 4.4V)
So current cannot increase to 300, but increase to a value such that Ve is 0.6V less than Vb.
You don't apply 0.6 V to the base. As shown in your diagram, you apply 5 V to the base via the current limiting base resistor. As I tried to explain in my post and as Collin explained in post #3, it is the base-emitter voltage Vbe that needs to be ~ 0.6 V to turn the transistor on. Therefore the emitter voltage will be lower than the base voltage and the load (LED) will not see the full supply voltage.
Okay, Vbe~0.6 V to turn the transistor on .
For that Base is supplied with 5V through a current limiting resistor and emitter connected to GND(In common emitter config),
but in common collector config base is supplied with 5V but emitter is not connected to GND(it's connected to one end of load not GND). There's nothing at the emitter(no + volt or GND) since load is OFF. Isn't it like Emitter left open? So how could Vbe ~ 0.6 in common collector mode if E is not GND)??
Also Why that resistor is called current limiting resistor.?
If base supply is 5V and base current say 300 mA then,
Rb = (5-0.6)/0.3 = 14.67 ohm
Which means that the excess voltage (5 - 0.6 = 4.4V) is dropped using the resistor. So isn't it limiting the voltage??
If I use a resistor in base, voltage across load will be much less than 5 - 0.6,
won't it be 5 - 0.6 - drop across base resistor?? is it necessary to have a resistor in base?
(I assume or hope you have an LED with integrated current limiting?)
If I use a 5V LED, why would I need a resistor in series with LED?
