I work in the trailer manufacturing business.
We use LED tail-light clusters.
The modern truck/tractors utilise a computer system to perform diagnostics
on various systems within the rig. One of these is the lighting system.
A pulse is sent to each tail light, the system monitoring the current. If
there is current flow, it is assumed the incandescent globes are OK.
Unfortunately, the LED lamps draw such a small amount of current that the
computer does not see a "filament" and flags a major fault on the truck
dashboard. In addition to the error message, the system continues to send
curent pulss in the forlorn hope that things at the rear of the rig have
improved. This causes the entire suite of LED lamps to flash like a
low-class disco!
There are ways around it. Some manufacturers have placed incandescent globes
in parallel with the LED lamps, others have used high wattage resistors.
Neither is acceptable for obvious reasons.
There must be a way to "tell" the computer that the LED lamps are fine by
emulating the current drawn by an incandescent globe, without using the
solutions noted above.
Do any of you outstandingly brilliant contributors have any novel and
innovative ideas?????
Maybe the idea requires a different approach. Just how smart is the
computer? Can you fool it into believing that the trailer is not
there? Will the computer continue to test the trailer in this case? Is
there a "trailer present" sense wire in the harness to the trailer? If
not, then how does the computer distinguish between the case where the
trailer is not present and the unlikely case where *all* lamps have
failed? Does the computer understand the difference between no current
draw and insufficient current draw?
If the trailer isn't there, will the lamps still work, ie does lamp
voltage appear at the connector? Does the computer sense the brake
switch and then supply power to a lamp, or can the brake switch
control the lamp independently of the computer? What happens if the
computer fails? Do the lights still operate? This may be a silly
question, but do the lights behind the cabin still operate when the
trailer is attached? If not, then this would indicate that the lights
are under computer control and that the trailer's presence is being
sensed.
-- Franc Zabkar
Please remove one 'i' from my address when replying by email.
