Hello, all.
I'm looking for a color organ for my vehicle. I'll be running a total of 5m (16.4ft) of single-color LED strips, with approximately 15ft of wiring, for a total run of approximately 30ft. I'd like to wire them to a color organ so the lights flash with the stereo's bass notes. To do this, I will use the Pass-Through RCAs on my amplifier with an RCA -> 3.5mm adapter cable. The LED strips are rated to draw 4500mA at full power.
I have tested my theory with an Oznium "Music Beat LED Controller," a 9V battery, and a small light strip. It works as intended when hooked up to my amplifier, but the Oznium device has a "feature" I don't like. It randomly switches between two modes: One is Lights OFF, flash ON with input; the other is Lights ON, flash OFF with input. This repeated reversal creates a haphazard light show which appears random, and it defeats the purpose in my application. I have confirmed with Oznium that it cannot be changed, so I'm looking for something else.
What I'm looking for:
Single channel organ
12-24VDC
Sustain 4500mA draw (larger capability would be nice for future use)
3.5mm line level input
Default: Lights off
With signal: Flash lights at varying intensity based on input
I have a few questions:
1) Is there something like this on the market? I'm only seeing DIY kits (usually with microphone input) and $150+ units.
2a) Would the ~30ft run cause a noticeable delay at one end, or will all lights appear to flash simultaneously?
2b) For synchronicity, would it be better to use two pairs of wires out of the organ and power half the lights with each one?
3a) Is it within the site rules for me to offer to pay someone to build this?
3b) If yes to 3a, is this thread okay? Or should I post in the Sale/Wanted section?
I don't currently have knowledge, experience, tools, or space to build this myself. A workbench is first on the list when I buy a home later this year! I'd be happy to provide any other information that may assist you fine folks in helping me.
Thank you,
- Tim
12-24VDC
Default: Lights off
Thank you,
- Tim
