Coil electrodynamics
K
Karl Roberts
Can anyone please clarify the following for me?
Two part question:
If I take a solenoid and feed a positive DC offset sinewave (ie. 6V
max 2V min) into one end and an inverted copy with a similar negative
offset (ie -2V max -6V min) into the opposite, what, in terms of
electrodynamics, occurs within the coil?
If I now split the coil in half and ground the center point, what
happens now?
Karl Roberts
Phil Allison
"Karl Roberts"
Two part question:
** The voltage across the coil varies from 4 to 12 volts in a sine wave
fashion - IOW an 8 volt p-p sine wave with a DC component of 8 volts. So
a current will flow in the coil that depends on it's impedance at the
frequency of the sine wave AND it's DC resistance.
The mag field inside the solenoid will be in proportion to the instantaneous
value of the combined currents.
happens now?
** This is ambiguous.
What does '"split the coil in half " mean ?
Grounding the center point has no effect, on it's own.
Good enough for homework ??
.... Phil
K
Karl Roberts
"Karl Roberts"
But don't two identical waves 180 degrees out of phase cancel to zero?
Or does the symetrical DC component change this?
I gather from your kind reply, the answer to the last question is
"yes".
This is what I am trying to visulaize/understand.
Karl Roberts
mike
Two part question:
It melts.
Phil Allison
"Karl Roberts"
** Only if they are summed.
In your example the coil sees the * difference *.
As any load connected between two terminals does.
Very basic stuff.
Try " sci.electronics.basics " - next time.
.... Phil
DonMack
"Karl Roberts" wrote in message
Two part question:
happens now?
Do you realize that voltage is relative? You can add any voltage to one
point as long as you add it to any other and the "physics" will not change.
So, your first case is identical to setting one side to 0 volts and the
other side to (2sin(wt) + 4) + (-4 - 2sin(wt)) = 0. So both ends of the coil
are at the same voltage. I could have set one end to Zeta(wt)^w +
cos(wsinw(wt))^t and wouldn't have changed anything.
In the second case when you ground the center you end up with two coils. You
can separate them mentally or even physically since you know(or forced) the
center(or even some other point) to be a certain value. It is exactly the
same when we know(force or decide) that something is "ground".
Note that this is distinctly different from the first case. In the first
case we have one coil and the second case we have two... but each one
similar to the others.
Anyways, if you think about it a bit you shouldn't have any issues. Use
resistors instead of coils. The only difference with coils is that the
voltage drop across the coil may not be linear due to self and mutual
electromagnetic effects and fringe effects.
Phil Allison
"Don Mack"
" If I take a solenoid and feed a positive DC offset sinewave (ie. 6V
electrodynamics, occurs within the coil? "
change.
** That is completely absurd.
The two voltage sources are summed in series, so the total is 8 + 4sin(wt).
So both ends of the coil are at the same voltage.
** Drivel.
** More absolute drivel.
** Take your own advice - fool.
.... Phil
K
Karl Roberts
Karl, it may be easier to convince yourself that Phil is right by
considering what would happen if *identical* signals were applied to
each end of the coil. Now that's cancellation.
In that case, given my original example of a + and - 2VDC offset for
each idendtcal sinewave, there would be a residual DC current flow at
4V from one end of the coil to the other.
Going back to having one sinewave inverted from the other, I
understand (now) the voltages add to 12 and the composite signal is
riding on the same 4V current.
Is that all correct?
OK, that's my last follow-up.
Karl Roberts
Phil Allison
"Karl Roberts"
" J.A. Legris"
** FFS pal - you just contradicted yourself.
The new case is VERY DIFFERENT from yuor example !!.
** Thick as a plank.
The offset voltage is 8 volts - cos that is the AVERAGE value of 8 +
4sin(wt)
The sine wave both adds to and subtracts from the DC offset - giving 4 and
12 as the min and max values.
.... Phil
Phil Allison
"Karl Roberts"
"Phil Allison"
What? ... and get answers from more people like me.
** Hey dickhead.
Have a look and see who is supplying most of the answers.
The NG is about basic electronics, like your question.
.... Phil
MrTallyman
"Karl Roberts"
Where do see the application here being that of a solenoid? He did not
mention one.
Since you seem to think he is referring to a solenoid maybe?
MrTallyman
John Fields expressed precisely :
No I just explained the difference.
And I try not to be abusive.
And I try not to show how clever I am with net lists that basics
enquirers have no chance of understaning.
IOW, you react with: "When slapped, I dance like a little girl..."
Now, you tell us that you cannot even grasp a 100% *BASIC* netlist.
Logic 2
John G 0
John S
mention one.
Always wrong as usual. Look in the first sentence following the "Two
part question:" above, AlwaysWrong. Damn, you're stupid.
Since you couldn't find your ass with both hands, AlwaysWrong.
