code for running 2 relays using 2 push buttons
hie ,
i would like to control the energizing and DE-energizing of two relays using push buttons and displaying information on an LCD .. using PIC16F877A iv attached my hex file and Proteus circuit
I would connect my LEDs to the Collector of Q2 and Q3 through suitable resistors, so you get the actual status of the relays.
What programming language are you using? C, Assembly?
Have you managed to write any code to operate the relays using switches?
im using mikroc and proteus yes i wrote a code but the buttons are not responding iv attatched my code
  • push btn.txt
I'm not familiar with PICs and the microc dialect, but there seems to be missing the code for setting RD1_bit and RD2_bit for output.
Make sure your analog pins are disabled. Add denouncing for Push button (wait for button release for few mSec). I would try the code without LCD first, once my relays are working, I would work on LCD.
In your code, I am do not see you calling while() loop in the main function?
I've added and modified some parts of your code. See attached.
You have not setup the input and output pins, this should be defined first. Then set at the start of your main function, I've added these to your txt file.
You also end the main function early with a parenthesis '}', I've deleted this from your code and the word 'else' from the second IF statement since it is not needed. Errors like these should have been picked up when you compiled your code.
I would recommended writing a simple code, just to get your leds on/off with a small delay to make them flash. Then included your push buttons, if the leds dont work.. you know there is a problem with your push button code. Then once this works, add control of the relays.... and so forth.
Another tip.. keep your definitions simple. Long worded definitions can easily be spelled incorrectly. For example:
uppersliddinggate >> UpperGate or Up_Gate
Using a capital or an underscore in-between words allows them to be read easily. Programmers need all the help they can get to make life simple.
  • Push Button Modified.txt
thank you so much
