Code causes error report from PIC CCS compiler
Hello, I need to help
I need to write code for interfacing gps tracker to p16f877a usin ccs c compiler and i need to proteus file, thank you very much.:)
this code give an erorr, can you test it and tell me what is the problem? :) :)
#include <16F877A.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NO DEBUG,NOCPD
#device *=16 // This enables use of all RAM.
#use delay (clock=20000000)
#use fast_io(b)
#define use_portb_lcd TRUE
#include<lcd.c>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#use rs232(baud=9600, xmit=PIN_c6, rcv=PIN_c7, parity=N, bits=8, ERRORS)
#define BUFFER_SIZE 96
BYTE buffer[BUFFER_SIZE]; // implemented as a circular buffer
int comma = 0;
int dataLen;
int start, end, speedLen=0;
int i;
char speed[10];
char c;
short ReadSerial = 0;
short startok = 0;
int8 index,x;
double parseData() // this function parses the $GPVTG data strings to find the speed information
dataLen = strlen(buffer);
for (i=0; i<dataLen; i++)
if (buffer == ',')
comma++;
if (comma == 7)
i++;
start = i;
while (buffer != ',')
speedLen++;
i++;
end = i-1;
break;
for (i=start; i<=end; i++)
speed[i-start] = buffer;
speed = '\0';
return atof(speed);
#int_rda
void gps_isr()
{/// note this routine needs to as short as possible since it is called
/// for each char received from GPS
c=getc() ;
putc(c);
if (c=='$')
index = 0;
startok = 1;
buffer[index] = c;
index++;
if (index>BUFFER_SIZE)
index = 0;
if ((index>62) && (startok==1) && (buffer[3]=='V') && (buffer[4]=='T') && (buffer[5]=='G'))
startok=0;
disable_interrupts(int_rda);
readserial = 1;
#separate
void reset_serial()
ReadSerial = 0;
index = 0;
for(x=0;x<BUFFER_SIZE;x++) buffer[x]=' '; // reset input buffer
enable_interrupts(int_rda);
int main(){
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED, 0, 1);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
enable_interrupts(GLOBAL);
reset_serial();
set_tris_b(0x00); // set the b port to the output
while(1)
if ( readserial == 1 )
lcd_init(); // initialize the lcd
lcd_send_byte(0,0x0d);
lcd_gotoxy(1,2);
printf(lcd_putc,"\f SPEED = %f",parseData());
delay_ms(1000);
reset_serial();
KrisBlueNZ
Sadly passed away in 2015
What is the error and what line is it on?
The error message from the compiler should give you a description of the type of error, and its location.
Telling us what the error message is and where it occurs is absolutely necessary.
Apart from that, I see a possible runtime problem here:
Code:
if (buffer[i] == ',')
comma++;
if (comma == 7)
i++;
start = i;
while (buffer[i] != ',') /*<- there is a risk that i becomes > dataLen if by chance the memory at that location contains "," */
/* possibly from a previous buffer content. */
/* The check ( i<dataLen) that is in the for-statement is not active here */
speedLen++;
i++;
end = i-1;
break;
But I doubt that this is the error your compiler detected.
Code:
comma++;
if (comma == 7)
i++;
start = i;
speedLen++;
i++;
end = i-1;
break;
Thank for your comment but, what is the true to became good.
can you help me,please.
the erorr shows below.
The compiler is telling you that it doesn't know what delay_ms is.
Your options are:
1) find the correct name for this routine.
2) find (and include) the correct library containing "delay_ms"
3) write your own delay_ms
This line
Code:
should be amended to
Code:
while (buffer[i] != ',') && (i<dataLen))
This is only one obvious code snippet I found more or less by chance. You should check the full code for other problems.
KrisBlueNZ
Did you fix the delay_ms() problem that was causing the compiler to report an error as shown in post #5?
Does your code compile properly now?
What is the symptom of the problem? In other words, what does the code not do that it should do?
