I
ianw
I have been having intermittent problems with the clock on my video
recorder.
When on standby the clock fails (displays ----) and hence will not
autostart or record from standby.
On opening the box it appeared that the clock crystal had been secured
to a copper pad on the pcb with a white silicon-type substance (heat
sink? But not sticky). The crystal had 'popped-up' and was no longer
in contact with the pcb.
Since re-securing the crystal (by pushing it down) the clock has
behaved itself.
I was not aware that a clock crystal needed either heat dissipation or
the 'can' grounding?
Is this a red herring?
The PVR is a Humax PVR9200T and the crystal is ...
Manufacturer: AEL CRYSTALS
Order Code: SCC4065
WATCH CRYSTAL 32.768KHZ
Frequency, output:32.768kHz
Accuracy, frequency +@:20ppm
Accuracy, frequency -@:20ppm
Temp, op. min:-10°C
Temp, op. max:60°C
Capacitance, load:12.5pF
Temperature stability +@:50ppm
Crystal case type:Watch A
Temperature stability -@:50ppm
Thanks,
Ian
Perthshire
recorder.
behaved itself.
Order Code: SCC4065
Temp, op. min:-10°C
Temp, op. max:60°C
Thanks,
Ian
Perthshire
