Hello. I've built a class D amp. I need some help.
Have a look at my video here:
As you can see, amplifier works perfectly to about 75% volume. When I take the volume past this point the speaker output starts to 'chop'.
When I connect just one speaker this problem does not occur, I'm able to turn the volume all the way up and it is LOUD.
However, with two speakers, obviously requiring more current, it doesn't seem to reach full volume without chopping.
The battery I am using is 12V rated at 1-2.4A output current.
The chip is a TI TPA3122: http://www.ti.com/lit/ds/symlink/tpa3122d2.pdf
Speakers are 10W RMS 8 Ohm.
Gain is set at 20dB.
I've checked the data sheet and this battery should be more than enough to power both speakers. Is it possible that the cheap Chinese battery isn't delivering the current it says it can deliver?
Any feedback/help would be greatly appreciated, thank you!
EDIT: These will be useful:
