Hello All,
I'm trying to build a Class AB amplifier to push an audio signal through an 8ohm speaker. I've opted to go transformerless and intend to use diode biasing. I'm also using BD135 and BD136 transistors. My circuit essentially looks like the circuit below except I have VCC as +15 VDC and 0V as -15VDC. I understand that the resistors I use between the voltage rails and the transistors will drop 14.3V regardless of value as the diodes drop 0.7V (Kirchhoff's Voltage Law). The resistors will however change the amount of current going into the bases and hence will effect the amount of current flow available on the output. I'm using Multisim to simulate my design and I am only getting a power dissipation of about 60mW @ 100mA in the speaker load with the resistors set to just 10ohms. I have a function generator set to 1V @ 1kHz but I don't think that matters here. Is there something I'm missing? Am I going about this design the wrong way? If you need more info, just ask and I will provide gladly.
Kind Regards,
MD25
Kind Regards,
MD25
