Any bright ideas out there for high current connections to power
circuits, surface mounted on clad Al substrates?
Got any links to the clad Al substrates? Is this the Bergquist stuff?
Is the Al always insulated from PCB traces?
I assume that, if it's a pc board bonded to an aluminum plate, you
must use all surface-mount connectors.
Is this stuff cost-effective? You could just bolt a PC board onto a
hunk of aluminum or a heat sink, but then you could provide clearance
holes for serious thru-hole connector pins, and use the mounting bolts
(with proper washers!) to connect to the substrate and use it as a
conductive layer.
At the moment, the only practical hardware seems to be SMD .050sq post
double-row male pins. There may be registration issues with these. The
Al substrate is not friendly to locating retainers.
I like to use 0.25" faston blades on pc boards for high currents, with
the female mate crimped onto harness wires. You can parallel these for
higher currents, with the wires acting as current-balancing ballasts.
But if you're limited to surface-mount, you'd have to be careful, use
a *lot* of copper on the board, so that the connect/disconnect forces
don't rip the tabs off the board.
How much current? How many circuits?
John
