Hi
Im new to the forum so im not sure this is in the right section but im needing some help with my project-
It consists of 240v power in to a 12v power adaptor then to 5 motors, each motor is turned on after the next one using a mini switch, after the motor has turned to its finishing position it triggers the mini switch to start the next motor and likewise until the last motor will trigger a warning lamp light and that will stay on until the circuit is reversed.
I have have 3 pin mini switches which i guess are the ones i need and i can roughly work out how to wire it one way but im hoping to have one switch that can power it both ways, meaning for example a push switch that activates the circuit one way when pushed once and at the completion of the circuit the same switch when pushed will reverse the circuit.
Really hope someone can help.
sam
sam
