circuit to provide strong push/pull force?
ben bitdiddle
I'm looking to build a device that will need to exert a fairly significant
pushing and pulling force- it will need to pull up the hasp of a
combination lock(once it's unlocked). I've seen schematics online for a
device that uses some massive solenoids- does anyone know of a more
compact way to deliver a large force using a circuit? If solenoids are the
only way to go, recommendations would be appreciated. I'm not sure how
much push force I need yet, i'll need to hang weights on the lock hasp to
find out. Are there any reasons for getting just one push/pull solenoid
vs. two push or two pull solenoids? thanks for any advice.
the Wiz
How about a low speed gear motor with an arm on the output gear? The gear motor
can provide appreciable torque.
More about me: http://www.jecarter.com/
VB3/VB6/C/PowerBasic source code: http://www.jecarter.com/programs.html
Freeware for the Palm with NS Basic source code: http://nsb.jecarter.com
Drivers for Pablo graphics tablet and JamCam cameras: http://home.earthlink.net/~mwbt/
johnecarter at@at mindspring dot.dot com. Fix the obvious to reply by email.
Don Taylor
A small motor turning a threaded rod through a nut?
dan
What's that Lassie? You say that ben bitdiddle fell down the old
sci.electronics.basics mine and will die if we don't mount a rescue by
Fri, 09 Apr 2004 21:01:39 -0400:
try electric car door lock actuators
