Phil Allison
"JB"
** You should seriously consider changing from relays to zero crossing triac
control. This can work well with electronic LED, incandescent and small
transformer loads used with low voltage halogen.
In the case of LED and CFL lamps, the high inrush surges commonly seen are
reduced by a factor of at least 5 because voltage rise time is controlled at
0.1V/uS with zero switching.
The MOC3062, 240V zero crossing opto driver and a 16A triac ( possibly a
snubberless type ) would be a good start.
.... Phil
This is really only to test the absolute worst case for inrush current for
the given load. I like to have some 'headroom' when I'm specifying the
relays in our products which switch these loads in the field, so I need
worst case scenarios. It only has to work on 50Hz supplies and is only for
in house testing purposes here in the lab.
.... Phil
