I have a little project I need some assistance on. I have some circuit
design experience, but not enough to know what I need to make this
work.
I have three long wires that I need to test for resistance. If the
wires are corroded, connections are bad, etc. that will be indicated
as a larger resistance than if the wire is intact. Usually the cut-off
is 3 ohms for a bad wire. The wires are under lots of stress, so they
develop breaks and the pins on the ends get pulled out a lot.The pins
also corrode, causing problems.
I need to set up a circuit that will light one of two LEDs or lights
for each wire. A green signal for a circuit resistance of less than 3
ohms, a red signal for more than three ohms. The wires are installed
into a system running at 12 VDC about 0.5 amps.
The idea I have so far is a comparison system. If R1 is less than R2,
then turn circuit three on. If R1 is more than R2, then turn circuit 4
on. Repeat for the other two circuits.
Ideally, the system would have an on/off switch and a single power
source. I plan to use a battery since I intend the system to be
portable. I also plan to have at least one other circuit in the same
system, so the battery would power that circuit as well and there
would be a switch to toggle between test circuit A and test circuit
B.
Any help would be greatly appreciated. I would like to be able to fit
the completed system in a small project box, probably 4 inches by 3
inches or thereabout. I plan to get supplies wherever I can get them,
so the more simple the components are the better.
I can solder just about anything, though I haven't tried surface mount
yet.
Thank you.
work.
B.
yet.
Thank you.
