circuit design help: momentary switch activates/cancels electronic switch
matthewuw
Here is the application:
I have a momentary switch. When I press it, I want to switch something
on (light bulb) and have it stay on even though momentary switch was
released. maybe 500 mA draw.
When I press it again, it turns the light bulb off. How do I do this?
This is in a 12VDC circuit.
Thanks!
K
Ken Taylor
Do you particularly want to use that switch or would you be prepared to swap
it for a push-on/push-off momentary action one?
Ken
E
ehsjr
Thanks!
There are a number of ways to do this. Do you want
to learn, or are you just interested in having
a circuit that will do it?
Ed
matthewuw
Will in the end, I need a circuit to do this. But I do want to learn.
What I asked for is actually only part of the functionality, but I see
it as a building block to start with and was hoping I might figure the
rest out on my own.
matthewuw
Well a push-on push-off switch isn't really momentary. It feels like a
momentary switch, but doesn't function like one. I have to use a
momentary switch, no option because or existing hardware.
matthewuw
momentary switch, no option because of existing hardware.
Terry Pinnell
Thanks!
This should do it.
http://www.terrypin.dial.pipex.com/Images/Momentary1.gif
There are many circuits for a 'toggle' or flip-flop, but that's the
simplest/cheapest I know of.
K
Ken Moffett
Thanks!
I've tried this and it works. Simple and cheap. Sub in a 12vdc supply and a
12v relay.
http://beradio.com/news/radio_pushonpushoff_switch_2/
F
Fred Bloggs
You can use a miniature SCR bistable:
View in a fixed-width font such as Courier.
Jim Thompson
Thanks!
See "TogggleFlopAncient.pdf" on the S.E.D/Schematics page of my
website.
...Jim Thompson
F
Fred Bloggs
Here is a less parts intensive version of the same thing, consumes about
50uA in the off state:
F
Fred Bloggs
website.
...Jim Thompson
A little before my time, but those were the days...toggle on release.
K
Ken Moffett
and a 12v relay.
I looked back at the circuit again and noted something they had left out.
The relay in their circuit was a 12vdc for the 24v supply. So for a 12v
supply you would choose a 5vdc or 6vdc DPDT relay. The resistance of R1,
R2, and relay's coil would all be approximately equal.
matthewuw
Okay, thanks for all the replies. Sorry to change things up on
you...but like I said early on, this is a learning experience for me.
It has occured to me that I don't want to worry about contact bounce
and that in reality, this will fit my application much better if there
are 2 momentary switches. pressing one of them turns the system on and
pressing the other turns the system off. i can probably adapt this
setup somehow from some of the provided circuits, so I will look into
it. this might actually simplify the circuit too i would think.
THANKS!
Terry Pinnell
THANKS!
How much simpler can you get than the circuits posted? Have you tried
any of them yet?
Hey, how about an even simpler approach: a single toggle switch? No
buttons, no electronics. AC or DC power supply in at one side, and out
of the other to whatever you want to control. Its explanation is as
follows: when you switch it one way, the circuit is powered on. When
you switch it the other way, the circuit is powered off again. Very
reliable, parts easily obtained. What's more, it has another advantage
over a button-based approach: the status of the circuit is always
visibly obvious (providing the two switch positions have been marked
accordingly, e.g. 'On' and 'Off' or whatever.) This advantage over
buttons applies even if the load has failed somehow (lamp filament
burned out, motor stalled, etc).
F
Fred Bloggs
.. 12VDC>---+-------+-----+-------+
.. | | | 12VDC |
.. | | --RELAY---
.. | | |\ COM|
.. | 1N4001 |/ NO |
.. o +-----+ +-----+
.. -| SWon | | |
.. o | | |
.. +----[2.2K]---|-------+ |
.. [2.2K] | |
.. | | LAMP
.. +-------+--||< IRF510 |
.. o === | |
.. -| SWoff 0.1U | |
.. o | | |
