Hi All....I'm glad everyone is still interested in this project !
@ Steve, will do
@ Rleo
Like the idea of the trap and your FF trigger circuit. One of the restrictions on the design h of the detector is that the range master must allow it. It might be hard to let them allow me to put a metal box on the ground behind my target, so I don't think I can do anything really different with the target.
This need to conform to the the typical shooting range makes things more difficult. That's why a short spacing on my original detector idea is appealing...
A short spacing is good partly b/c the effectiveness of barrier materials can be checked and because the range master will likely allow it
Plus it's hard...
@ CDRIVE
I 'm super interested in the uC and the Picaxe. I suppose that the baud rate is the limiting factor. I know that National Instruments makes a uC PC interface card for event timing and they use an external crystal to the uC for the additional sampling clock resolution. If I could debounce and do a little signal processing with software ( assembler even ) that would rock. A mathematical 'analog' filter is not that hard to program and would also be good practice for me considering I want to be in the signal processing field.
First, I am determined to learn how to use FF and the digital components !!
I have some pics of my bread board set up...it's messier than I want....
TODO: List
For practice, I want to debounce my counter-display reset switch with RC debouncer.
Get NOR gates and make FF and test both Steve and Rleo's gate designs.
Fix my clock, it's only outputing 40 mV amplitude at correct freq of 10 Mhz.
I might need to try a Colpits oscillator, I don't have much experience with any oscillator.
The one I'm using is just an RC circuit with a crystal and a NOT gate for feed back. I'll post a link to the page of this thread with the PDF and the circuit.
I'm temped to try sticking a biased JFET amp on my existing clock and see if I can get it swing higher. I also need to practice basic amps....lots to practice.
I should be at work !
cheers,
wbg
