Hi team!
Thanks for all your help in the past! I've got another question (what a pain I am, I know!)
OK, so here's the situation. I'm building my own windmill which requires active control. I have a 24V lead-acid battery stack at the bottom of the windmill (in the garage). At the top of the windmill I have a 24V motor which is steering the device and which requires power the power. I've got some electronics controlling the direction the windmill is facing being controlled from a very low power PC on the ground with the battery stack. I therefore have 2 wires going up to my windmill to provide power and a USB cable to do the driving with. The power cables are quite thick (2.5mm^s) as I need to be able to drain a few Amps at 24V when I do the steering and the cable is 25M long (to get it away from my house). Steering only happens a couple of times a minute at worse.
This works ok, but I want to put in place a situation where if the cable bringing the power breaks or the data communication cable breaks, or coms stops for some reason, the windmill returns to a parked position. This should be pretty easy - my plan was to put a relay and another pair of smaller 24V batteries at the top of the windmill and when the main power cable is disconnected (or lower batteries are dead), the relay falls and turns the steering motor to the park position using the power supplied by the top pair of batteries.
So, I have two questions! 1) how can I charge these batteries and 2) how can I use the batteries to augment the supply from the bottom batteries?
The charging point is a difficult one. To charge the upper stack I need to have a voltage that is at least a few volts higher than the voltage on the upper batteries. Even if the lower batteries are fully charged, if the upper ones are not pretty empty the voltage loss on the cable means I won't have enough volts to start charging. I'm guessing I need some kind of DC
C charger or step-up device?
The augmented supply is also difficult - how can I make it so that supply is being fed to the motor from both batteries rather than the lower stack but also have a cross battery charging system (top to bottom?)
My initial thought was that I could have DC
C converter that stepped up and charge the top stack, and that then both the bottom and top stack could be connected through reasonably sized diodes onto the load. I've drawn this in the attached (simplified) diagram.
Do you think this will work? Or is there something else I need to do?
Many thanks,
Neil
Many thanks,
Neil
