W
William P. N. Smith
I'm looking for a charge controller to charge a 48V battery bank from
a higher voltage array, does anyone know of one that'll take 300 to
600 volt DC input and charge 48V banks?
Because of the ease of wiring for high voltage arrays, and the normal
use of these arrays in a grid-tie application (probably using the SMA
Sunny Boy), and the layout of the building's roof, there will be as
many as 8 high-voltage arrays and up to 5 inverters.
If the grid power goes down for long periods of time I'd like to be
able to charge the batteries that run the critical systems using the
solar panels, but it'd be incredibly inefficient to just connect the
(4 amp) arrays directly to the batteries...
Does anyone make such a beast, or has anyone solved the islanding
problem with grid-tie arrays? There will probably be a generator, but
I can't guarantee that the load will always exceed the array output,
FWIW.
Thanks in advance for any thoughts!
FWIW.
