Adrian Tuddenham
This circuit (except for D53 & D 54)) has been working in a Compton
Melotone cinema organ for about six months and has given no trouble:
http://www.poppyrecords.co.uk/compton/TrebleAmplifier.gif
A few days ago it failed with both O/P transistors (Tr 61 & Tr 63)
totally short circuited on all three terminals. Fuses blew and
everything shut down gracefully.
The connection marked "From Z" is held at a couple of volts & 1
diode-drop below the + 30v rail during normal operation, but rises to
the +30v rail when the amplifier is muted. Until this week, the muting
facility had not been used - the failure occurred shortly after the
amplifier was put into muted condition for the first time.
The instant of failure coincided with the organist pressing a toe piston
which operated several 24 v(dc) solenoids. These are (obviously)
inductive, they draw the best part of an amp each and have unsuppressed
self-break contacts to switch them off as soon as they have mechanically
toggled. Their wiring is independent of the amplifier but runs "all
around the houses" in the vicinity of it.
I replaced the blown O/P transistors and checked for other faults, but
found none, the amplifier is now working again.
My diagnosis was that a transient had occurred on the loudspeaker wiring
when the O/P transistors were muted and effectively open circuit; it had
driven the collector of one of them beyond the power rail and caused a
base-emitter reverse breakdown. The excessive current then propagated
further failure in the opposite transistor of the pair.
To prevent this happening again, I have added D53 & D54
Has anyone experienced this mode of breakdown (or heard of it occurring
elsewhere)? Is there another, more likely, failure mode which I have
overlooked?
overlooked?
