Car parking aid
butthead
I would like to build a car parking aid. It's like a proximity sensor.
Can anyone help by sendin some info or links or schematics? By the way
what is better to use: sonar, ultrasound, RF, IR...?
K
Ken Taylor
butthead said:
Suggest you try a search engine; +"car parking aid" +circuit reveals plenty
of hits.
Ken
Jim Thompson
Can't you just park like they do in Mass2shits... by ear? Clang!
Clang!
...Jim Thompson
Joel Kolstad
....or hanging a ball from a thread from the garage's ceiling?
Jim Yanik
[email protected] (butthead) wrote in
How about a cheap miniature video camera and a inexpensive LCD video
display? Seems it would be simple to implement.Your backup lights probably
give enough nighttime illumination.
Jim Yanik
Or by nailing/screwing a 4x4 to a piece of rubber-backed carpet as a stop
block.
default
American Science and Surplus had a reasonably inexpensive one ready to
go. Uses ultrasound and lights three LED's as the car approaches the
end of the garage.
H
Howard Henry Schlunder
SOund NAvigation Ranging, or sonar, is more or less the same thing as
ultrasound, except that it implies the transmission medium is water. I
doubt your car is ocean worthy.
RF is worthless as a parking aid as various things which you don't want to
run your car into are transparent to it, aside from the fact that it
propagates at the speed of light and is therefore useless for measuring very
short distances with.
Most things aren't transparent to infrared light, but given that they
reflect different levels of it, it can't readily be used for measuring
absolute distance with, at least not without knowing how reflective the
object is ahead of time. I suppose some exceptionally smart software and
optics could determine a distance for you, though, given that digital
cameras can automatically focus themselves.
Ultrasound is a tried and proven technology which stikes me as the most
logical technology to use. You might wish to take a look at "Good old'
parking sonar [
http://www.geocities.com/CapeCanaveral/Launchpad/3632/sonar.htm ]. It seems
as others misuse the terminology too.
Howard Heny Schlunder
in message
news:[email protected]...
Active8
block.
wouldn't it be easier to nail the carpet to the 4x4? ;-)
Paul Hovnanian P.E.
butthead said:
The factory installed systems appear to be using ultrasound. The have
multiple sensors on the bumpers, spaced about a foot apart so that the
system doesn't miss narrow obstacles.
Given the parts count involved, I have to wonder if a CCTV system
wouldn't be cheaper. And more flexible too. You can use it to line up a
trailer hitch. Put a little red LED on the rear view camera and it might
discourage tailgaters.
Barry Lennox
I use a yellow sticky "dot" on the wall, Mk 1 eyeball it at 90
degrees.
Barry Lennox
I
Ian Buckner
degrees.
Barry Lennox
My father-in-law used a "calibrated" tennis ball hung from the
ceiling,
arranged to just touch the rear window when the car was positioned
correctly.
Regards
Ian
