Car battery in UPS?
notme
Observing proper safety (ie, not using it inside the home), is there any
reason using a car-sized 12v gel-cell (eg, Optima*) would be a Bad Idea (tm)?
Form-factor is not an issue; the battery would be outboard, of course.
Charging time would be much longer considering the modest charge current of
the UPS, but so would be the discharge time.
Opinions?
Thanks.
*<http://optimabatteries.com/optima_products/yellowtop/index.php>
Sylvia Else
Opinions?
Thanks.
Are you sure the available charge current will exceed the self-discharge
of the battery?
Sylvia.
Nico Coesel
Opinions?
You should use a sealed battery. Car batteries may leak accid and H2
gas. Most UPS I've seen have a fuse in series with the battery. Make
sure to retain the fuse. I'm not worried about the charge current. An
UPS is usually fully recharged in a couple of hours.
PeterD
Opinions?
Thanks.
Any deep-cycle LA battery would work.
Martin Riddle
any
Idea (tm)?
current of
Opinions?
Thanks.
Should work with out a problem, except for charging.
IF you want an indoor friendly battery look at the AGM, they don’t gas
like LA's.
Cheers
notme
That's a *great* primer on LA batteries of all types (liquid, gel, AGM,
deep-cycle); there's not a type that's not described.
"Myth: The old myth about not storing batteries on concrete floors is just
that - a myth. This story has been around for 100 years, and originated back
when battery cases were made up of wood and asphalt. The acid would leak from
them, and form a slow-discharging circuit through the now acid-soaked and
conductive floor."
Thanks!
Martin Riddle
AGM,
just
originated back
leak from
and
conductive floor."
Thanks!
Heres the real Battery FAQ <http://www.batteryfaq.org/>
Cheers
Rich Grise
You say, "Car-sized"; but you haven't said if it's a car battery or a
deep-cycle (RV, Marine, golf cart).
Don't use a car battery. They're good for 600 cold cranking amps, but
crap for deep-cycle applications.
If it is, in fact, a deep-cycle battery, then there should be no problem,
as long as your UPS can keep it charged, as has been mentioned.
Good Luck!
Rich
