I am building a robot that is using two 350 watt electric motors http://www.monsterscooterparts.com/24v-350w-motor-11-tooth-25-chain-my1016.html
I ran into a small issue. Usually you want to suppress electrical noise by soldering two capacitors to the terminals and the casing. However, the terminals on my motors are inside the casing. Would it still suppress noise if I soldered them to the wires close to the casing?
