Capacitor size to repel birds?
I'm looking to build an electric bird repeller using HO scale railroad
tracks. What size capacitor would be appropriate to give a sufficient
shock to a bird to repel it, without hurting it?
Thanks in advance.
Robert Baer
Thanks in advance.
First, design a trebucket (sp?) launcher and yse capacitors about 1/4
to 1/2 inch insize; a rock would be better.
no_one
Robert Baer said:
First, design a trebucket (sp?) launcher and yse capacitors about 1/4 to
its actually trebuchet
David Gravereaux
Try a cat instead.
"That's the problem with science. You've got a bunch of empiricists trying
to describe things of unimaginable wonder." -Calvin
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGyd9ylZadkQh/RmERAkBhAJ9zvNNEVKBd4avTr4HaNtrat8hp5wCcD/mV
vM2x8meaUwJZzcDrX2+Im70=
=Z6E8
-----END PGP SIGNATURE-----
K
Karl Uppiano
Thanks in advance.
There is nothing unique about a capacitor that makes it suited for shocking
things. A capacitor merely stores energy. You can store energy in a battery,
you can get the energy from the power utility, you can generate it with a
windmill.
If I were you, I would use an electric fence charger/energizer. Just connect
the terminals to the track rails and plug it in. It is designed to inflict a
painful but harmless electric shock. I have been "bitten" by electric fences
on many occasions. It is not something I would do voluntarily.
http://electric-fence.com/Shop/electric-fence-chargers-and-energizers.asp
The voltage on these devices might be a bit high, causing the rails to arc.
You might want to investigate how electric fences are typically installed,
and use similar construction, with the same kind of wire and insulators.
David Gravereaux
Jasen said:
and this was approved for usenet?
yuck!
User-Agent: slrn/0.9.8.1pl1 (Debian)
You could ask the authors to make your nntp client RFC compliant like it
should already be. rfc3156 is like 6 years old!
iD8DBQFG3IdrlZadkQh/RmERAjJFAKDlrIl/YP3okf52f7eapXJ/DwERGACeJw0/
+0oVUriUP785dOJUsSLDOuA=
=ACeY
David Gravereaux
Direct from rfc1847:
A MIME agent that includes support for this framework will be able to
recognize a security multipart body part and to identify its
protected data and control information body parts. If the value of
the protocol parameter is unrecognized the MIME agent will not be
able to process the security multipart. However, a MIME agent may
continue to process any other body parts that may be present.
The last sentence is the meaningful one. Please pass the bug onto the slrn folks.
iD8DBQFG3IrKlZadkQh/RmERAr9AAKCBugx3a/0EnaNk7hcdueLQOSpuIQCgn/HE
7OGhmdrYW586+Whz+RkXFuw=
=HEDK
