Sir pete geeeeeeeeeee . . . . . . .
ALL BEHOLD . . . now . . . instead of your units original split up / two piece schematic, you (
a tout le monde) now have yourselves a
UNITIZED one page version, with my added mark-ups that are being the involved circuitry, flow paths, and switch actions of just your specific . . .
CAPACITANCE LEAKAGE . . . . problems that you say are being experienced.
Your voltage readings supplied are indeed way off base.
BUT you need an answer for Steve . . . me too . . .
ME TOO ! . . . as to what the KNOWN situation on this kit is.
HAS IT EVER BEEN KNOWN BY YOU, TO WORK IN ALL OF ITS TEST FUNCTIONS ?
If not, I
INITIALLY suggest to take a .05 or .1 ufd cap and use the bridge function to test the cap and see if you can get good eye opening and closure at the point where you are rotating the units top balance control for the caps reading of value.
That then lets us know that the 6BN8 - 6E5 and their support components are functioning.
Design wise, this is being a superior unit by virtue of the additionall use of a triode amplifier and then a voltage doubling of its output before feedig into the tuning eye display inicator. All the other units just use the triode within the tuing eye tube.
Also they voltage double the filament voltage that is also used for the supply voltage to the bridge test circuitry.
After you have given feed back on the capacitance shakedown test in bridge function, I would then want to confirm the
HEAVY
LETTERING above . . . .
FOR CERTAIN.
ADDENDA . . . . just now caught your earlier posts confirmation )
That then leaves considerations of wrong component install, component installed in wrong place, high value resistor drift, capacitor leakage or short or since being a kit . . . . mis wire.
If being so I can then fill you in on a 1000% successful manner of checking out the units wiring and components , by virtue of my past hands on experiences of having been involved with some of the greatest electro- mechanical complexity in the universe.
For accomplishing that, you will need to go down to ye olde coppie-shoppie and throw down a whole fiffie-tew cents of yer hard earned munnies on the counters and have a mag up of this made.
Either have it laminated or be prepared to cover it at home with some clear plastic and hold down tape . . . . . should their price for that laminating be excessive .
I now stand by for your feed back . . . .
Thaaaaaaaaaatsit . . . . .
Le Gran Schematique . . . .
73's de Edd . . . . .
Fifteen days ago, I read that smoking can kill you;
The following day I stopped smoking.
8 days ago, I read that drinking can kill you;
The next day I stopped drinking.
Yesterday, I read that having sex can kill you;
This morning I stopped reading.
